2001 BMW 330ci (E46) Harmon Kardon Business CD: BT3 Installed But Can't Connect
I was able to install my new GROM-BT3 in my 2001 BMW 330ci with the Harmon Kardon system (many thanks for the excellent installation video). I successfully connect via Bluetooth every time I turn on my Business CD head unit.
However, as the car didn't come pre-installed with a CD Changer, I can't find a way to engage the CD Changer settings to listen to music from my iPhone 7s Plus. Is there some setting I can make in the Business CD head unit, or some wiring adjustment I need to make in the trunk area?
  • So, just to clarify, you can't access the GROM mode (which in CD changer mode in your install), is that correct?
    Does it have a CD button? If so - you need to press it. Sometimes twice. Alternatively if there is MODE button - press this one instead, until you are in CD changer mode (which is GROM mode).
    There is no any programming for CD changer needed for your stereo.
  • Hi Admin,
    • Yes, that's right. The model 330ci I have didn't come with a CD changer installed.
    • Yes, it does. I tried pushing the CD button twice (didn't work) and I can't find a MODE button on my head unit.
  • I recommend to open the tech support ticket at https://gromaudio.com/support.html The tech specialists will be able to help you.
  • OK ... tech support ticket opened. I sent one earlier, but got no reply so I applied to join this Forum.
  • Still no reply from Tech Support. Is there anyone else I can contact directly to address this?
  • Apologize about it. What is the ticket number so we can take a look what is the status of it?
    Also, sometimes the replies end up in the spam folder, so we recommend to check there.
  • UPDATE: DECEMBER 2018
    Well, after a couple months of trying to find the time, I just worked on trying to get my BT-3 finally connected to my BMW Business CD deck.
    The suggestion I was given from GROM was to T-splice the BUS wire, since those particular Posi-Taps typically don't work since the BUS wire is much smaller. I definitely followed the advice and made a very solid T-splice, wrapping the GROM wire around the exposed BUS wire, and cleanly wrapping it with electrician's tape.
    Annnnnnd ... no go. :-(
    Granted, I'm able to connect my iPhone 10 XS MAX easily to the GROM via Bluetooth, but I still can't get my Business CD to show any CD changer functionality whatsoever. Clicking the CD button twice doesn't work at all. There's no Mode button on a Business CD, either.
  • So, does the music from your iPhone plays via GROM Bluetooth and through the car stereo now?
  • No. :-( The Business CD doesn’t act like a CD changer. The only thing it will play is from the single CD slot.
  • There should not be any issues. Please check with tech support via https://gromaudio.com/support.html Also GROM car kits come with one year manufacturer warranty. If you purchased the system from us, and it is still under warranty, we can also replace it.
    Thank you, and sorry for the difficulties with GROM equipment.
