I have a 2006 Lexus GX470, could use some guidance..
  • I have a 2006 Lexus GX470, could use some guidance..
    I like the idea of the TOYNU3 plus the BT dongle and the 3.5mm + 5V USB charging options.
    My question is; Does this offer the exact same functionality as the TOYNB3 when it comes to Bluetooth?
    Or do you get greater functionality when you go with the TOYNB3 vs the TOYNU3.
    I have some follow up questions for both.
    1. Does the stereo make a popping noise when the Bluetooth connects and the device turns on?
    2. Will my phone autoplay whatever the last thing I was listening to when the Bt connects?
    3. If YES, then is it possible to disable this?
    4. I assume with either of these options one has the choice to bypass the built in Lexus BT completely and utilize the included microphone and simply use the Grom BT for calling as well as BT audio streaming?
    5. Is one better at displaying the text of what you are playing on the factory radio than the other? Or do they both display track information comparably?
    The TOYNU3 + BTD Bluetooth dongle will give you the same functionality as the TOYNB3 in terms of the Bluetooth - hands-free phone calls and wireless music streaming, plus integrated controls via your factory car stereo.
    To answer your questions:
    1. Usually, the stereo does not make a popping noise when the Bluetooth connects. However, some stereos might do it. So we cannot guarantee 100% yours
    will not do it.
    2-3. Usually, your phone will auto-play the last thing you were listening to. You might check your phone's media settings and see if you can disable it.
    4. Yes you can completely bypass the factory Bluetooth. Ensure that your phone is disconnected from the factory Bluetooth. You can use the "forget" Bluetooth connection function on your smartphone.
    5. They both display the track information comparably.
    Here is what will fit your 2006 Lexus GX 470:
    https://gromaudio.com/store/all-toyn_lex4_.html
