Tip: Enable the split screen for LEX78 and LEX9 stereos (Lexus 2016+)
  • Tip: Enable the split screen for LEX78 and LEX9 stereos (Lexus 2016+)
    On the newer Lexus stereos that are using the LEX78 and LEX9 models of GROM VLine VL2 and VLite VT2 system (https://gromaudio.com/store/all-lex78_.html and https://gromaudio.com/store/all-lex9_.html) you can use CarPlay and Android Auto full screen. Your stereo's native navigation should support the wide screen.
    However, if you want to get back to the split screen - for CarPlay or Android Auto and the OEM screen at the same time, here is how to:
    1. Exit the AUX source/VLine UI (Go to AM/FM source for example)
    2. Go to the Factory Navigation
    3. Enable the split screen for the Factory Navigation
    4. Enter the AUX Source/VLine UI and it should adjust (If it does not adjust, restart the vehicle)
    CarPlay on Lexus using GROM VLine VL2.
    CarPlay on Lexus with VLine Split Screen
    what is the difference between lex78 and lex9? I am having Lexus lx570 model 2018( with navigation).it appeared both versions were compatible with this car as per the descriptions provided.
    Anyhow I tried to split the screen but didn't work even restarting the car didn't work. (vline updated to latest version)
