My Vline emits the ignition noise through the speaker system. Anybody has an idea how to earth the Vline?
Vline engine ignition noise
Could you let us know the year, make, and model of the vehicle?
The VLine is typically grounded directly to the radio, so this noise should appear in other sources as well. If the noise is appearing in all sources outside of the VLine2, I would recommend checking the battery to see if it needs to be replaced. You can also check the Battery's ground to the Chassis to ensure it has not rusted or come loose.
If you need quick support, please open a ticket with us here:
https://gromaudio.com/support.html
