Need help with AA on VLite in 2015 Volvo
  • Need help with AA on VLite in 2015 Volvo
    I have a 2015.5 Volvo V60 with the VLite module installed.
    I have an issue in Android Auto where I cannot switch between the main panel and the bottom ribbon to change apps. Per the manual, the "exit" button should do this switching, but it does not work.
    Per Grom audio support, there is no solution (software cannot be patched to fix). The only thing that would work is using a mouse in the USB slot on the VLite or installing a touch screen (which I really don't want to do).
    Has anyone else has this problem? Any work around that others have found to get AA working on Volvos?
    Thanks!
    Unfortunately there is a design flaw in AA that makes it possible.
    The best way to avoid that is to use the HOME button (assign in Settings) or AUDIO/MAP button that will bring the main screen at some point.
    Alternatively install the touchscreen that simplifies AA experience as well.
    https://gromaudio.com/store/vline_ac...vlite-vt2.html
