New unit bluetooth connection skipping
amdina
I just installed a TOYNB3 (order #149681) two days ago. I tested the unit before putting the dash back together and there were no issues. It worked again today when I began driving, but after a few minutes the audio began to skip. I disconnected the bluetooth then reconnected and the same thign happened - worked fine for a few minutes then began to skip. Please advise.
Can you check if the BT3 unit is installed in the space where no metal parts obstruct the Bluetooth signal? We usually recommend the glove box compartment. If you thing there are no metal parts that can affect the signal, please contact our technical team at https://gromaudio.com/support.html They will help.
