We released the VLine VL2 software update 5.3.0.0
Changelog:
4973. Camera: added the frame_height errors statistics
5312. Fixed "Infinite Splash Screen on boot" (USB storage checking bug)
4202#c87. Fix removeContainers skipping fullscreen node when only one item exists
4579. Use NetworkCapabilities VALIDATED for internetAvailable + status events
5307#c8. Fixed Resetting Network
4846. NTP update fixed
5315. Added multi-touch support
4226#c16. Fixed USB/BT mouse in AA/CP
Set all DATA/CMD pins to low level during sleep (Fixed SD-card hangs)
4503#c2. Simplify Spotify categories, user Your Music categories as root
4948. GPS: Added support for Glonass, Beidou, and Galileo satellite systems
5339. Fixed black screen when selecting "Show UI."
5220#c5. Reboots VCore if userspace process is stuck during suspend (OPTEE issue)
Added ping monitoring. Restart vbased if there is no ping for 10 seconds.
5176#c12. Set AAuto DPI default to 160 for LEX_400
4974#c3. Locally trained models, new patterns format
4963#c21. Add an option to collect screenshots for AA/CP
4883. Introduced Out-Of-Band Bluetooth pairing for USB CarPlay
To update:
1. Connect VLine VL2 system to Wi-Fi.
2. Go to Settings --> System --> VLine System Updates --. Check for Updates and install any available updates. Watch how-to video:
https://gromaudio.com/installs/vlin...te-vline-vl2-system-firmware-using-wi-fi.html
Changelog:
To update:
