Power consumption notes
VLine is designed to work as fast as possible after you start the vehicle, at the same time consuming as little battery as possible. The normal behavior will be as follows:
- Within 10-15 minutes after ignition is off, VLine will stay fully up and running, able to process data and installing updates if needed. Most internal LEDs are on.
- After 15 minutes VLine will go to sleep, consuming around 28mA, ready to start immediately upon ignition. Only one internal LED will be on.
- After 24 hours of inactive ignition VLine will shut down fully, consuming 1-2mA. Ready to work in 20 seconds after ignition is on. No internal LEDs are on.
