Tip: LEX78T, LEX78, LEX9T, LEX9, LEX9L and CarPlay Android Auto microphone
  • Tip: LEX78T, LEX78, LEX9T, LEX9, LEX9L and CarPlay Android Auto microphone
    for LEX78T, LEX78, LEX9T, LEX9, LEX9L models of VLine VL2 system that work with the factory mic, if the CarPlay/Android Auto does not recognize the voice commands - it means that the factory mic is not performing well enough for the VLine. The remedies are:
    1. Go to the VLine main screen (VLine UI) and tap on CarPlay or AA icon (depends on what you are using)
    2. There is an option to Adjust the microphone's gain - put it to 45
    If adjusting the microphone's gain does not help, you can use an aftermarket microphone (either the one that we supply with the other VLine models or an aftermarket one such as Kenwood or Pioneer—the one designed to work with aftermarket GPS systems).
    Here is the link to the microphone that works well with VLine:
    https://gromaudio.com/store/accessor...eless-mcs.html
    I have the aftermarket mic in my 2010 Lexus IS350 and it sounds terrible to people. Should that gain also be 45? Or is that only for the factory mic?
      Is that the mic that comes with VLine? If so, you can try 65. If that will not help, contact our support at https://gromaudio.com/support.html
