2017 Lexus Nx 200t, When I start my car I get the carplay signal on my iPhone but it does not load up on the car's screen. It shows the factory map and GPS and only shows up if I go and change the car's media then it pops up. I have the settings to connect automatically and appear automatically but it still does not show up.
Grom and Carplay not loading automatically.
Did you do this step after the installation?
IMPORTANT STEPS TO PERFORM AFTER THE INSTALLATION!
Turning OFF Auto Screen Change in the Factory Settings
For VLINE mode to function correctly, the “Auto Screen Change” option in the Lexus infotainment system needs to be turned “OFF”. If this function is not turned off while using the VLine, the image will switch automatically to factory GUI screens on its own after 10-15 seconds have passed.
To turn this function OFF: 1. Press the MENU button > then go into SETUP > select GENERAL
2. Scroll down until you see the option line AUTO SCREEN CHANGE.
3. Select OFF for AUTO SCREEN CHANGE. Make sure to hit SAVE
