BT3 muted or no sound but only with European spec OEM head unit
  • BT3 muted or no sound but only with European spec OEM head unit
    As the title says, BT3 muted or no sound but only when used with the European spec OEM head unit.
    No problem using USB3 with the European spec head unit.
    BT3 works fine with Acura and JDM spec head unit.
    Car: European spec Honda NSX.
    GROM device: BT3 (MBUSDB3)
    Detail on NSX Prime here:
    https://www.nsxprime.com/threads/gro...t-only.221334/
    Basically, after successfully playing music through BT3 via both the Bluetooth and the AUX input, if you change the head unit mode to radio or switching it off, you’ll no longer manage to play any music afterwards through BT3.
    Only happens when used with European spec head unit and no problem when used with Acura or JDM spec head unit.
    As in the above link, it's almost like BT3 went into muted mode because increasing the volume control on the head unit has no effect on the background sound/noise even at max setting.
    In fact, no background sound/noise at all and just dead silent.
    One potential cause is the difference in head unit mode selection.
    With the JDM and Acura unit, when mode selector is pressed, it will cycle through as follows;
    AM -> FM -> CD -> back to AM
    With the European spec;
    UKW (FM) -> CD -> LW -> MW -> back to UKW
    As mentioned, even with the European spec head unit, GROM USB3 works fine.
    Hope someone at GROM can look into this and update the firmware.
    Thank you.
    If you're experiencing issues with BT3 being muted or having no sound specifically with a European spec OEM head unit, it can be incredibly frustrating. This problem often arises due to compatibility issues between the head unit and certain Bluetooth protocols. If you're struggling with similar technical challenges or need help crafting an argumentative essay on related topics, you might want to check out services like https://writepaper.com/write-my-argumentative-essay. These services can provide valuable assistance, ensuring that your arguments are as clear and effective as possible—much like resolving the sound issues in your car!
      Since USB3 works fine but BT3 doesn’t, GROM might need to update BT3’s firmware to ensure proper reactivation after mode changes. Have you reached out to GROM support directly?
        Interesting issue! It seems the European Honda NSX head unit has a unique interaction with the BT3, especially after switching modes. Since USB3 works fine, perhaps firmware adjustments targeting the European UKW radio cycle could solve the BT3 "mute" problem. Reminds me of the responsiveness I'd want while blasting through Moto X3M levels – instant! Hopefully, GROM can address this soon.
