UI Issue after Android 12 update 07 Lexus LS460
  • UI Issue after Android 12 update 07 Lexus LS460
    Vline 2 for 2007 Lexus LS460. Updated to Android 12 and downloaded Gapps, no problem. The issue is as follows....
    In Android 8, you had a dedicated left side UI that had a up / down button. In Android 12, You must hit the red circle on the left side to "trigger" left sidebar UI (which I find annoying). Worse, the left sidebar UI up / down buttons does not work in my music app PI Music player. I'm unable to scroll up and down through my music onscreen.
    Please advise / help!
    Hi. I also have ui issues. After updating, I installed gapps and all the apps are in portrait mode. I also have the same issues with the navigation bar as the original poster has also stated.
    please help. Thank you
      I am having some issues too. Only got AA back up and it is not in split format like it has been for months, its like the old version. Was fine right before the update. 2016 Honda Odyssey.
        I'm getting these issues too, in addition selecting right hand drive in the settings doesn't move the navigation bar like it did on 8 it just makes the menu pop up on the right.
        exploreco have you tried lowering the DPI in the android auto settings on the unit, if you keep lowering it eventually the screen should show in split mode again
