Can't seem to do an over the air update. My current version is pretty old, from 2021. When I tried to download the update, I get a Write File Error - Permission Denied. This is for both the Vline Update and the Firmware Update.
Can't download updates, get a write file error
Here is the video that explains how to do the factory reset on VLine Vl2 or VLite VT2:
https://youtu.be/rHmFtFPuwvg
Please contact our technical team at https://gromaudio.com/support.html They will check what is going on with your specific set up and will provide some help and guidance.
I had same issue with my VL2 but GROM Customer Support helped resolve as follows:
Do you have multiple users set up on the VLine? If so, go to the second page on the Vline and select users and make sure the first one is the user logged in.
This will cause the same error with resetting and also effect updates as well.
This was causing my error loop, once I went back to the first or default ‘User’ the GROM came with - my error message went away and I could download and install my VLine and Gapps updates.
Thank you GROM CS!
Hope this helps others
- 2 likes
