How to use factory FM radio and VLine Maps at the same time
  • How to use factory FM radio and VLine Maps at the same time
    On some, but not all vehicles, it is possible to use factory FM radio and keep VLine Maps (or CarPlay / Android Auto) active on the screen at the same time. Here is the short write-up how to enable it for different models of the VLine VL2 / VLite VT2:
    LEX5 / LEX5LS / LEX4 / LEX3 / LEX3L / LEXGS / LEXGX - while in VLine mode simply press FM. The FM overlay will appear at the top of the screen.
    LEX7 / LEX89 / LEX9: You can go to the FM radio source, then press and hold MAPS (or MENU if MAPS is not present) for 3-5 seconds, and then the VLine should appear.
    LEX7T / LEX8T / LEX9T -
    1. Go to FM (or XM) source on the radio
    2. Tap the upper right corner 3-5 times
    3. VLine should appear while FM is playing
