When installing VLine VL2 Infotainment system into Lexus LS 460 2007-2009, it is very important to connect to the reverse wire, according to the instructions. Without connecting to the reverse wire, the VLine will not function. Make sure that you create solid P-Tap connection between two wires, and the wires are actually connected.
Check the latest video from GROM Audio technical team:
Let us know if you have any questions. Here is the link to the reverse wire install addendum:
https://gromaudio.com/docs/vline_man...L_addendum.pdf
