Vline 2 - 2001Lexus RX300 - Some Android 12 issues
  • Vline 2 - 2001Lexus RX300 - Some Android 12 issues
    Just updated to the new Version 12 update and got a few issues below to add to a bug list, if there is one.
    1) Backup camera does not work anymore via the Yellow RCA Cable. It does enable but the video feed looks like it is it tearing.
    Click image for larger version  Name:	image0.jpeg Views:	0 Size:	49.8 KB ID:	1186
    How it used to look below:
    Click image for larger version  Name:	image0 (1).jpeg Views:	3 Size:	54.1 KB ID:	1187
    2) Wired Apple Carplay does not work anymore, bluetooth Carplay works fine; I've tried a couple USB wires and also the official apple cable and unfortunately doesn't connect. I am on the latest iOS17.5.1 version if that helps.
    3) Small issue - Side bar that has the back button does not stay put in the settings and sometimes disappears on the main app screen when it boots up.
    I'm the same. Wired CarPlay is bricked. I also have a red box around everything that makes clicking almost impossible. Wired CarPlay asks me enter USB debugging mode, it's actually outrageous that it has been released. On top of that the wi-fi won't connect and the whole things is unusable.
      Thank you for the post. Finally able to upgrade to Android 12 with help from tech support but my camera is having same issue. Also can't click on settings button to disable factory camera.
        As of now, updated to VCore ver: "V2SC 4.3.0" and it seems to have fixed the wired Carplay ability. Backup camera and navigation sidebar still having issues.
        • #5
          We are releasing the patches, please keep updating the system.
          • #6
            Updated to V2SC 4.4.0 (Also did a factory reset as well):
            1) Backup camera issue still persists
            2) Navigation side bar is "Kinda" fixed. On boot it appears fine, but when Carplay is enabled and you go back to the GROM app/homescreen (from the Carplay screen) it disappears.
            • #7
              Updated to V2SC 4.5.0
              2) Navigation side bar still disappears/cuts off
              Click image for larger version  Name:	image_175.jpg Views:	7 Size:	103.2 KB ID:	1257
              • #8
                Updated to V2SC 4.6.0, just some small bug fixes
                • #9
                  Updated to V2SC 4.7.0, just some more small bug fixes
                  1) Backup camera issue is still tearing when activated through the yellow RCA cable.
                  • #10
                    Updated to V2SC 4.8.0 which just came out not too long ago.
                    • #11
                      Updated to V2SC 4.9.0. Issues confirmed resolved!Thank you!
                      • #12
                        Thank you for posting the progress and follow up, we appreciate it!
