Grom vline2 failing to start up randomly
  • Grom vline2 failing to start up randomly
    I have a 2007 Lexus GX 470. I installed the GROM vline 2 about 2 months ago. Since the install, I've gone from android 8 up to android 12.. My issue is the random failure of the GROM Vline2 to initialize. All I get is a black screen . Everything else that is not connected to the GROM will work. The record is 3 days in a row with Everything working. The shortest is one key turn. My current fix is to unplug the power supply to the GROM, wait 5 seconds, then plug in power connector. All will work just like normal. If you don't pull the connector, the screen stays blacked out. Doesn't restart the GROM. It's very embarrassing when showing off this upgrade and it fails to start up.
    1. Ensure that you are using the latest firmware and software updates. Here is how to check and update:
    https://youtu.be/UrQ2TWJ5v1Q
    2. If you are using the latest available firmware and software versions, please contact our technical team at https://gromaudio.com/support.html They will look into your specific setup and see why it is happening.
