Moving LEX89VL2 from 2014 IS 350 nav to 2014 LS 460 nav
  • Moving LEX89VL2 from 2014 IS 350 nav to 2014 LS 460 nav
    Is the LEX89VL2 compatible with the 2014 LS 460 with nav? When I look up the VL2 product page, it only says 2015 and up which doesn't seem right given 2014 was the start of a new generation. If I search for a compatible model with the vehicle search, it pulls up the LEX78VL2 which apparently is also compatible with the 2014 IS 350. Are these VL2 models interchangable between these vehicles?
    Yes, the same system will work with the 2014 Lexus LS 460 nav. Both vehicles use the same system model.
    Here is the link to the LEX78VL2 model:
    https://gromaudio.com/store/vline/grom-vl2-lex78.html
    Under the compatibility tab it lists both Lexus models - 2014 IS 350 nav and 2014 LS 460 nav
