Lexus ct200h - won't switch to rear camera while on phone call
  • Lexus ct200h - won't switch to rear camera while on phone call
    Hi,
    For a while i thought I had some issue with my reverse cam, but recently I figured the pattern
    While I'm on a phone call and switching to reverse the cam wont won't, hanging the can and switching to Drive and back to reverse works
    bug ? intentionally ?
    Car - Lexus CT200h 2016
    Phone - Connect via Android auto wirelessly
    Thanks ahead
    We recommend you update the firmware to the latest available. Check here how to:
    https://youtu.be/UrQ2TWJ5v1Q
      I'm on the latest firmware
        If you are using Android Auto, but not in the phone call, will the reverse work normal for you?
        We recommend you to contact our technical team at https://gromaudio.com/support.html
        They will review your specific setup and provide with help.
          Hi, same issue here on latest updates. This is a new issue that did not used to happen. Over all this version is working very well. Mines a JDM 2011 using a LEX6RT adaptor. Cheers
          • #6
            Thank you for letting us know! Please report to the technical team at https://gromaudio.com/support.html
