Can you move a LEX7VL2 from a 2013 CT200h to a 2014 GS350?
Move from CT200h to GS350
It should work just fine. Also, you might need the latest version of the power interface cable MCFLEX78. The LEX7VL2 and LEX89VL2 were recently merged into LEX78VL2. Check the compatibility here:
https://gromaudio.com/store/vline/grom-vl2-lex78.html
The MCFLEX789 is the correct cable for the 2015 Lexus GS350. Please ensure that the unit itself says "LEX78VL2" at the back of it (on the silver sticker). Also, ensure that you connected the GVMF video cable at the back of the display, and not at the back of the stereo. There might be the same plug at the back of the stereo that will fit the GVMF cable, but you need to connect to the back of the display. Here is the link to the install manual:
https://gromaudio.com/docs/vline_man...manual-web.pdf
