CarPlay spoken directions volume is too low, how to adjust it?
  • CarPlay spoken directions volume is too low, how to adjust it?
    If you are using CarPlay and the spoken directions volume is low, here is how to fix it:
    There is a setting in iPhone to control music volume and audio for iPhones and when toggling it on then off (if it was off) or off if it was on has fixed a few different scenarios now. The setting is called "Sound Check"
    Sound Check can be found by going into the iPhone and going to SETTINGS -> MUSIC -> SOUND CHECK. Its job is to essentially change audio levels depending on where the iPhone is seeing audio come from.
    Try to toggle it "Off", or if it is already "Off" - turn it "On" and then back "Off", and see if that will help.
    1. Step 1 - go to the iPhone settings and select "Music".
    2. Step 2 - locate “Sound Check” and turn it off, then restart the iPhone. If the “Sound Check” is already off, turn it “on” and then back “off”. Restart the iPhone.
    If you will keep experiencing difficulties with the CarPlay spoken directions volume being too low, contact our friendly technical team at https://gromaudio.com/support.html We will help!
