How to install new door speakers and tweeters on Toyota RAV4 2013-2018 with JBL Sound | GROM Amplinq
Front Door Speakers
Rear Door Speakers
Tweeters
This video series shows you how to disassemble the door panels of a 2013-2018 Toyota RAV4 with JBL and replace the speakers
at their OEM locations. We also show you how to replace the OEM tweeters with Air Motion Tweeters for crispy, clear car sound. We are using the Amplinq Car Sound Upgrade System
Amplinq Amplifier Retrofit and Car Sound Upgrade System
for select Toyota 2012-2025 with JBL car stereo systems.
Amplinq Car Sound Upgrade System consists of:
Amplinq Amplifier Retrofit Interface and DSP;
Two 4-channel NVX amplifiers with the OEM-matching connectors;
Amplifier Mounting Plate;
AMT Tweeters with the OEM-matching connector harnesses;
Door speaker connector harnesses and mounting rings;
Subwoofer harness and mounting ring;
Foam and sound-dampening materials.
Shop at https://gromaudio.com/store/amplinq_kits/grom-kt1-toy30.html
About Amplinq Car Sound Upgrade System:
Amplinq Car Sound Upgrade system is designed to make the job of car sound upgrade as simple and straightforward as possible. Created
as a result of the extensive research and development by our team, the system consists of OEM-matching speaker and amplifier connectors
and harnesses, speaker adapters and rings, amplifier retrofit interface, and amplifier holding plates. We also provide recommendations
for the specific speakers, tweeters, subwoofers, and amplifiers that will allow you to achieve high-clarity sound
in your vehicle.
Our system focuses on clarity and giving each speaker a specific role, while also adding features like time alignment to tune for specific seats. As a result,
the sound in the car gets a crystal-clear, multidimensional quality.
Speakers, Tweeters, and Subwoofer that we recommend for upgrading the car sound in the 2013-2018
Toyota RAV4 with JBL. The components we recommend are tested by us and are proven to provide high-quality sound
results at an economical price point:
Door Speakers:
Zhan Di 6.5-inch Carbon Mid-Bass Car Door Speakers D-M658B
or
HERTZ Cento Series C165L 6.5-inch Woofers (Amazon affiliated link)
Tweeters:
2.5 inch 4-OHM Air Motion Tweeters
Subwoofer:
JBL Stage 82
Speaker Rings Package for 2013-2018 Toyota RAV4:
Select Lexus Toyota 2001-2017 main speaker adaptor rings and harnesses (TOY30-MWA4)
Amplinq Sound Upgrade Beta Testing - a one-time opportunity for local DFW customers
If you reside in the Dallas-Fort Worth, TX area, you have the opportunity to participate in our Amplinq Car Sound Upgrade Beta Program and experience
a concert-quality sound in your own vehicle.
You will get high-quality sound and free professional installation by our top-notch technical team.
See if you qualify and contact us!
Additional Parts used in this project (affiliated links):
Premium Car Sound Deadening Mat 80 mil - check on Amazon
- Goes on the door frame and surrounding parts to decrease rattles and unwanted noise
Car Speaker Baffle Kits - check on Amazon
- Goes between the speaker and Adaptor, and seals the speaker to the grill (so no audio leaks into the door panel)
Closed Cell Foam and Heat Insulation Sheets - check on Amazon
- Goes between the door frame metal and OEM plastic/metal parts (ex., between the door handle assembly and the door)
2mm Speaker Adaptor CCF Tape - check on Amazon
- Goes between the Speaker Adaptor and the Door Frame to prevent air leaks.
Small CLD/Acoustic Foam Sheets - check on Amazon
-Went directly behind the speaker.
More info is available at http://gromaudio.com/amplinq
